How much boost?
EssexAaron said:
anyone that thinks a rebuilt engine with a set of forges make a engine any more reliable is crazy.
Of course it does, if you're running decent boost levels !
Of course, that's just part of the story.....
Paul
Rishi
Still waiting on some shims!
In that case I must be crazy!
Forged Pistons are stronger and disapate heat quicker than the standard Cast Pistons, which in turn makes them far more reliable especially at higher boost/heat/pressure levels..
i fail to see how 1.2 bar is high boost! thats what we are talking about on this thread.. ive been building engines for a long time, but cant be asked for a arguement
gunmetalgtir
Obviously you haven't been building them long enough to know that this statement isn't correct! :lol:
Radleigh
So why make that statement in the first place?!
It is for an engine, that uses components, that were only designed to run 0.7 bar at peak boost !
Paul
Rishi
Point is that its still more reliable with the Forged Pistons for the reasons i mentioned above.. It was the reliability that you were questioning..
The actual need for Forged Pistons for a standard turbo running 1.2bar is another question all together..
to save people money:?
Paul
now thats just stupid! you better change your rods,crank,valves,cams,cylinder liners blah blah
this is why i try not to get involved with internet arguements, i wont say no more on the matter
No, that's typing away without connecting brain ! ;-)
If you did any research, you understand that the pistons are the weakest component of the GTiR engine. And as a result, the part that's most likely to fail, if the boost is turned up ! :roll:
Paul
