Fuel pump relay
Fusion Ed
The ecu has two main power sources, one from the ignition, one it has all the time direct to battery (via fuse)
bopper
Ok i think the ecu is not getting a live and its just that i assumed the fuel pump before thinking the problem through, thanx ed for the help i will post up to let people what the actual issue was
bopper
Right i only managed 20 mins at the garage as i finished late then had to go out but the ecu has got live's and i put a ground to the fuel pump relay and the pump primed, so it looks like there must be a break between the ecu and the relay, ed said the relay was on pin 104 but how are they counted, where is pin 104??
