Engine Rebuild Parts
beau
pistons and crank bearings.oil pump rotors:-http://stores.ebay.co.uk/Erics-Performance-Parts/Nissan-OEM-/_i.html?rt=nc&_fsub=11296071&_sid=76590873&_trksid=p4634.c0.m14.l1581&_pgn=9oil pumps;-http://stores.ebay.co.uk/Erics-Performance-Parts/Nissan-OEM-/_i.html?rt=nc&_fsub=11296071&_sid=76590873&_trksid=p4634.c0.m14.l1581&_pgn=12not looking in the right places then beau!
i think that was the only place i found but was out of stock, bare in mind this was in august
beau
i spent ages looking, asked loads and bob looked too, i cant remeber where i tried but in the end had to use a used one
no body asked me either as i have 2 on the shelf ready and a set of new spare rotors.
bensmith907
As for the know how, My mate has rebuilt tons of engines before and we both have good engineering standards all we're lacking is the SR20det specifics. but (thats what these forums are good) all you have to do is pick out the good advice from the crap lol:-D
nimhbk
As dan said i got my oil pump, chain, chain tensioner, chain guide,and complete gasket set from erics
good prices and shipped quite quickly
bensmith907
Ive just been doing some reading on threads, some regular members say you can re use the head bolts. Ive looked on the Maintenence Manual and It says you can re-use bolts on SR20 DE and not SR20DET.
What do you reckon Bob, Danny or VSS Irvine? you'll know better than me. do I re use them or should I go new?
beau
i have re-used mine, as recommended by someone with alot of experiance, was advised only to re-use once though (my engine had never been apart so was ok)
bensmith907
Yes this is the page I was refering to earlier
http://www.gtirworkshopmanual.com/default.aspx?v=207
as I said before It states SR20DE, it says nothing about a turbo powered one I.E. SR20DET (I read this as, bolts shouldnt be re used on turbo engines) If anyone know a page that says otherwise I would appreciate seeing it.:-D
Im not being tight, infact I dont think my mate will even let me not put old back in. But I am really interested as to what is the Norm
vss irvine
they can be used but you need to know the history of them, not sure if the manual lists the length tolerances.
at end of the day its your choice mate, personally, if your going to the hassle of doing a full rebuild,
do it right, do it once.
bensmith907
Engine came out today...
Turbo is buggered- turbine housing is cracked from the wastegate to the outside of the housing that'll explain a few of my problems!
one of the engine mounts is completly buggered (rubber bit in the middle isn't attached at all)
lots of rubber gaitors are rotten through
sure there's more!
Any one any ideas about the turbo? anyone have one to sell or recommend a good seller? PM me!
