I had a blaster coil die on me after only around 5000miles,i think i have also read of the ignition boxes giving up also.
I just had a read of some of my old ignition threads which brought back some painfull memorys lol
Alot of my trouble was with plugs either giving up or finding the ideal plug gap.
I was and still proberly am suffering from either spark blow out or a set revs miss/burrble in the low revs depending on the plug gap.
I think after re-reading it i was getting spark blow out at mostly around 1.2bar plus on the standard setup unless running really small gaps,which in turn running the small gaps would make my low set revs miss worse.
I think the only way to get rid of the set miss was to open the plug gaps pretty wide but then i would get spark blow out.
With the msd stuff i think i still had to run conservative plug gaps to run higher boost but the spark blow out was gone(when using good plugs) but the low held revs miss/bubble/hicup was certainly more felt with the msd stuff especially in the low revs under 3000rpm where the msd mutiple sparks.
I think in the end i put this set revs miss down to lean mixtures, and reading that cdi ignitions are not as good with off boost/light load lean mixture conditions as the longer duration sparks of an inductive igntion system like the standard setup is,and thats why the cdi ignition mutiple sparks in the low revs or something?
I think i did increase the fuelling at a set rpm point on the safc once and it did improve the miss/hicup problem.
