Girl Racer
Thats great, not too far really, thanks
Thanks MarkIn Surrey! Just off the A3, although it's a bit of a roundabout way to get there.
Couldn't agree more, i'm at 1.7 bar on the same turbo and still using all the original ignition system.keep things simple, if the ignition system is in good order theres no need for all the msd stuff....its just likely to give you more headaches and problems
I thought your boost was coming on late. On the road is it hitting peak boost 1.4bar just over 5K?Sure Tim, call around one weekend.Its not much different to a normal one really until 4k ish rpm, then it starts going a bit mental.
I have Janspeed 3" downpipe which combines the dump pipe.On the road (2nd and 3rd gear), my .64ar 3071 passes 1.4bar on the way to 1.8bar around 3.4K 1.8bar at 3.8K. On the RR in 4th gear you can add 400rpm to that. I think Steve 3071 with .86 was similar and Dooie who was one of the first to use a 3071 many moons again was similar. It's probably not the cams as I also run 264's but I couldn't say what it is.
You have binned the standard elbow haven't you?
My other thought is that when I ran 1.6bar the car always felt more alive more of the time than 1.4bar. Maybe the boost controller is always holding the turbo back?
Between us all we'll get there.
Jim
