AEM EMS - Plug & Play Programmable Engine Management System
Thats the same ECU that Rishi is using I believe.
Looks to have everything you could want in an ECU.
PaulB
Looks good stuff that Scott, Im sure theres a tuner on passionford who can map this ECU, think it could be THOR Racing, but like Rob said, it has all the bells and whistles.
If you dont think youd use the features such as launch control and antilag etc, then maybe an Emanage would be more suited ?
Im running a standard ECU with a daughterboard, which works very well for me, and is fitted and mapped for around half the cost of the AEM ECU alone, albeit without all the fancy features.
Braveheart
Lou.... I'm very interested to see how you get on and good luck!
What other sensors and harnesses did you get with it?
Where did you buy it?
Cheers,
Scott.
LOU ROB
I've got the uego version and the wideband to go with it, a 3 bar map sensor, e.g.t sensor and an air inlet temp sensor.
The ecu plugs straight into thr=e gtir loom.
Rishi pointed me out to these guys AJ USA and they were easy to deal with.
LOU ROB
diesel weasel said:
you only planing on tickling that new engine of yours then lou :lol:
I might not even use that tubby mate, I am thinking of going even bigger due to the fact its going to be more of a drag car than road car.
you will still only be tickling it if you're going to use a 3bar map sensor :)
Braveheart
LOU ROB said:
I acheived 11.1 @ 130 mph over 2 years ago. Why is it taking so long for people to catch up ?
That's a very impressive 1/4 time.
Is it a case of catch up or figure out.... ;-)
Thanks for your feedback Lou as I look into my mods:thumbsup:
AshBhp
If wanted, i have a new AEM ecu in the box and air inlet temp sensor.
Also i can highly recommend an official AEM mapper with 4 wheel rolling road.
Pls PM me.
jpward
That be the 30-1600U then Lou?
Would you need to keep the stock EGO or does the wideband over ride this?
What about set-up regards MAF's MAP sensors and injectors easy enough to change settings?
jpward
Just wondering how does it stack up against the Autronic SM4?
And wheres the AEM offical 4wd roller located? Sumo's a dealer they have a RR?
