W
white lightening
Right, im driving down the road when i notice the water temp in the red and the oil temp over the half way mark on the gauge.
Pull over and there's steam everywhere and the rocker cover gasket has blown. Oil splattered all over.
Fired her up the next day, no white or black smoke but when out driving the car down the road i notice the oil temp getting hot very quickly.
I popped the bonnet and revved it and noticed its breathing heavier than normal from the breather pipe and the rocker cover gasket still leaks even tho its been replaced
Ive got a compression check and 2nd+3rd cylinder are at 100ish, the 1st+4th are both ok.
Its using a bit of water and v little oil. When driving off boost, temps are ok but as soon as i rev it above 3k oil temp starts to rise quickly to about the half way mark on the temp gauge i then i ease off and it drops.
Sounds like the h/g right??? But would this cause the oil temp to rocket and would this cause the heavy breathing??? :roll: :roll:
Cheers paul
Cheers paul
