wiring
What info does the gauge display mate ?
I'd normally expect the 'ign' wire on a gauge, to be connected to a ignition switched power point !
Paul
nismo-400R
what you mean what info it displays mate?ive got a red wire which needs to go 12vbattary,orange for ing,white which needs to be connected to the side lamps,then black for earth
nismo-400R said:
its a defi oil pressure gauge,need to wire up the defi link control unit 2 mate
This website will have all the info you need: http://www.nippon-seiki.co.jp/defishop/index.htm
There's pdf instruction manuals on there for the Defi link unit and all the gauges !
And you need to connect that 'ign' cable, to a decent ignition switched source... Like the cable coming off the ignition barrel !
Paul
nismo-400R said:
cheers for the link,which cable is it from the ign barrel mate?
Erm.... the big red one... :lol:
Sorry mate, I don't know off the top of my head !
Your best bet is to get a multi meter and go probing !
Paul
nismo-400R
why would you need to connect the ign wire,when your already wiring the 12v one which will make the gauge cone on/off anyway
I think it's because the permanent 12v +ve is for the gauge memory and the 'ign' is for the normal ignition switched power.
Doesn't it have a 'replay' function ?
Paul
