GTI-R Kid
Recently fitted a Wilwood 4-pot front brake kit with 310mm discs, but have been left slightly dissappointed in the way they work. When first fitted we dreained the entire brake system of fluid, and refilled it with the stuff Rally Designs supplied us with. We bled the system 3 times to ensure that any trace of air was gone from the system too, but now that they've been tried I can't say I'm overwhelmed by the performance.
When the brakes are first applied the pedal moves a good 2 inches before any proper braking force can be felt. If I let off again and press the pedal straight away the response is totally different and much better. Its like the first push of the pedal primes the lines with fluid, and then they work on the second press.
Is this a common thing after fitting 4-pots and retaining the standard brake master cylinder? There are no leaks in the system, not by the calipers or back at the master cylinder. Is it possible that even after bleeding the brakes 3 times that there's still air somewhere in the system?
Oh and the car is fitted with the Poly Q pads in case it makes any difference. I'll be replacing the rear discs and pads next week (no point having brand new up front and 4 year old stuff on the rear (though only 3000km use - car been stored for years). Think this might help things, or will I just have to bleed another few times.:sad:
