Those dual seat fittings are a compromise, I don't really like them. They'll seal ok but will deform the flare on the brake pipe a bit more than the proper concave or convex fitting.Looking at it the female flare has hardly any contact area, so I wouldn't be happy using it.
Getting it off the hard pipe on the body. - Once I got it undone it was really easy to change it at the other end and bleed the line.What was the problem fitting the clutch line? They're usually not too bad.
I wouldn't get too hung up on the od, what's inside is more important ;-)Yeah, I found a copy of that somewhere else last night Mark. Using those figures, the 3/16th double/sae converts to 6.91mm+-.18mm so 6.73 to 7.09mm. So my oversize flare is out of spec and my "small" one is in spec.
