Cheers Jon, do the wilwood calipers still require the Clio disc to be spaced out? i had been considering the evo3/fto caliper setup and read that the discs needed spacing a bit so started looking to see if any were better matches disc wise, not sure on the details of the wilwood setup so dunno if it would be different fit for yours.Good link, useful. I'm still on std dia rear discs, so will try and fit something bigger later. It has wilwood 4 pots on the back though. I like wilwoods, as they seem to work, they are relatively cheap, and the pads are cheap also
