vpulsar
30mins that's ambitious
Your right more like 30 seconds but I like to be optimistic about my performance mate lol.
A dude in The US was running 10,000rpm on a pretty stock VE head (springs and retainers). The stock oil pump was the weakest link.Who has the money? Rockers will be an issue at that so you are then onto vvl heads....basically you would need copper beryllium valve seats,stainless one piece valves,90lb valve springs and lightweight retainers, good light weight rods like carillo,an 82mm stroke crank (steel sr18 one),89mm cp or similar pistons,cosworth 90mm gasket,decent liners, everything dynamically balanced,stock head bolts,arp l19 rod bolts,arp main studs, crank scraper, dry sump kit, and a good machinest to do the bits to exact tolerances , 10,000rpm and reliable.
Thanks martin much appreciated
Yes, I agree that this would be very useful indeed. Also, I would be grateful for some information on when to use a head torquing plate during an engine rebuild. These head torque plates can be found (for example) here:step by step "how to" rebuild a solid bottom end (include basic tools, parts that should be replaced, tips and tricks)
That's what I thought, but it's nice to hear feedback from someone who actually knows what they're doing! :-D I am looking forward to reading your write-ups, they should be very helpful indeed!Just a quick answer to the torque plate thing, yes they are a good idea if you can replicate the plate to behave exactly like a cylinder head as bore dimension do change quite drastically on some engines when the head is bolted down, do you really need it for a up to 500hp road engine gtir...no tbh as you are not searching for perfection.....if you wanted that you would also need to measure the bores when the engine is at its design operating temps ala formula 1 etc
That'll be great Dan, look forward to reading it.Right, when I get back from holiday I will be doing the write ups that have been suggested , will prob start with bottom end engine builds, whys, what's and torque plates and when you need stuff, then head work and so on. It will all be posted up once the mods have ok everything and stuff.
Ok I think that is a good idea, especially after seeing the recent stories of cars blowing up etc after purchase and the others who have bought forged piston engined cars and then found that it is standard etc, I will eventually do a write up on gearboxes and diffs as I have good knowledge of those and the tell tales as what is what and guides on how to tell certain things like is it stock or aftermarket.Buyers guide would be great too. I dont think we have one of them.
you love em really Tom .Would be quite easy...
Dont buy one
In all seriousness it would be good, the amount of people whp buy cars with forged engines etc later to find they dont is daft,
