As above, what topic shall I write today for people, cylinder head work? Gearbox upgrades? Ideas people please.
Who has the money? Rockers will be an issue at that so you are then onto vvl heads....basically you would need copper beryllium valve seats,stainless one piece valves,90lb valve springs and lightweight retainers, good light weight rods like carillo,an 82mm stroke crank (steel sr18 one),89mm cp or similar pistons,cosworth 90mm gasket,decent liners, everything dynamically balanced,stock head bolts,arp l19 rod bolts,arp main studs, crank scraper, dry sump kit, and a good machinest to do the bits to exact tolerances , 10,000rpm and reliable.How to build a 10000+rpm engine. :-D
I'd like this one please :lol:As above, what topic shall I write today for people
On a Quaife 1st gear it would hit 60mph.;-)Funny thing is with a stock gearset the car would do 90mph+ in second gear...lol
How about a ride blog of what you have built instead of how things can built.
Ps. Still interested in seeing these cylindrical roller bearings for the center diff.
