nothing is wrong with itOk ill give them a try.whats wrong with there drive plate?
Wtf? I said bollocks as in ' ah shit, I've already got some and they are shite', that's why at the end I said anyone want to buy them.crack on then as it's not bollocks, if your trying to get a rise it won't happen. next thing you'll be saying is that you don't need a torque plate to bore ali block's correctley.
just wondered if anyone could tell me what sort of power i could expect out the setup im building my car too and give me any suggestions on how to go about it
spec as follows:
engine:
87mm wiseco pistons
std rods with arp rod bolts
std crank
full acl race series bearings
cometic 1.2mm head gasket
hks 264 cams
alu light weight flywheel
forge fmic and hardpipe kit
front exit exhaust
zytec ecu and aerospec loom with coilpack
tubular turbo top mount manifold
head fully recon'd
oil pump recon'd
brand new water pump
std headbolts
chassis:
tein s/s coilovers
hi-spec 300mm discs and 4 pot calipers
cusco front and rear strut braces
anti dive kit
whiteline a/r/b d-bushes
whiteline polybushed drop links
compomotive 17" mo6 alloys
goodyear eagle f1 tyres
im also planning on going for:
760cc injectors
gt3071 turbo
clutch undecided
gearbox recon'd or shot peened depending on power
run 1.5 bar boost
require turbo elbow
ive probably forgotten parts but this is a rough idea so if anyone can lend a bit of advice it would be appreciated
