anyone see any other major probs i would encounter by doing this conversion?
I can see a problem.....
this......
the funny thing is im actually seriously toying with the idea of mid mounting the gtir engine and fitting in a space frame to the rear but as close to the font seats as possible.
now whether this will actually ever take place is another story but i cant see as its that hard to do once you have the alignment issues worked out with the rear diff (which may need angling up a few degrees as the engine will sit on an angle towards rear)
it will also not cost much money to do just labour time really!
the hardest part will be making a strong enough frame to take the mounts as engine will need to be mounted from side of block as well as front.
would also need a cradle to hold tail end of gearbox.
the petrol tank would also have to go, as well as the centre floorpan. then would just need extended pipes from big front rad to engine.
you could also run some kind of ducting to engine to help with air cooling also.
i think it would be a great fun car pushing out around 450bhp through the rear wheels and the car should then be very well balanced without the big lumpy weight over the front wheels.
and the other good thing is that you can retain all the engine management system and wiring (it will just need relocating), this will then also give you the chance to fit a different kind of box off say a 200sx which shouldnt spill its gutts everywhere as the car will simply break traction when too much power is applied. but you could fit quaife or similar internals thus giving you a much more reliable car
no offence bob, but i really dont see how doing all this will make a reliable car?
