I've just started having issues with the battery light flickering and sometimes staying semi dimmed, sometimes flickrring fast then slow.
I've been to a workshop and they have done a charging, start and battery test and all has passed.
The light still flickers but it has developed an splutter which has gotten worse over the last day, I thought it was a ignition issue or a alternator issue due to the light.
ive pulled the plugs and now it's running lean, so possibly the pump is not getting the correct voltage?? the overflow has spat water out over the alternator but that has been recently relocated.
Now is there a possibility that this alternator could test up correctly on a machine but not function correctly when under full boost.
it would be good to get as much info as possible as the mechanics where I live don't know too much bout these things and I can't afford for them to sting me. Where should I start?
I've fixed up earths everywhere and the plugs are new
mods are
exhaust
front mount
1.1bar
remap
walbro
fuel filter is new
thanks
Denis
mods are
exhaust
front mount
1.1bar
remap
walbro
fuel filter is new
thanks
Denis
