VIEWS ON 'SPEC' AND 'ACT' CLUTCHES
B
beast14
wuz up fellas??....i just joined the forum.....i'm from trinidad, west indies by de way...........
i need a clutch really badd.......could ya'll give me some advice.........
i use my car everyday but drag race it sometimes on de weekend...
i'm thinking of mix-matching the two brands ie. spec 6 pock (with spring) clutch and the act xtreme pressure plate..........
Sirnixalot
Welcome to the boards 8)
neither company makes a GTi-R clutch. You can send them your stock clutch and have them make a clutch for you though.
I emailed spec about doing this before. They are willing to do it. Not sure on the price though.
B
beast14
thanks for de headsup........wat do you think bout mix-matching the two brands (if i were to get them)????
skiddusmarkus
Mixing still won't make them fit though.I've heard that S13 SR20DET clutches fit but don't know anyone who's actualy got one in their car.
If you do buy one that the tuner thinks will fit,make sure you get a money back guarentee.
What sort of power are you running? Why not just buy a clutch designed for the job (ie gtir)? and hello by the way. :D
Sirnixalot
manufactuers design their components to work with each other. using 2 different brands you take a risk that something will not work or it may give you extra slippage...or it may turn out for the better.
Also buying the components seperate will probably be more expensive than just buying a clutch kit.
Plus if anything goes wrong, they'll probably try blaming each other to get out of paying up. :?
B
beast14
thanks for all the quick replies guys!
what brands do ya'll use??????
and what specifications ie. copper or organic or ceramic, six pock or four, spring or solid........
cause i don't really want to buy something that will make everyday driving very difficult.....but when i'm on de track, i'd like to get great performance.....
right now i'm probably at 240-250hp......18psi....stock turbo and internals
but i'd like to eventually reach 300hp.....
cmng
Sirnixalot said:
price would probably be the reason.
emm but look OS Single plate it not expensive as everyone think
MRRP is about 98000 yen = 501 pound
then ADD 100 pound for shipping = 600
exclude VAT
remember that price is included with flywheel
and i have been using my OS Giken Single for more than 30000km
still lasting.
exclude VAT
still lasting.
so does that mean you get a cluch and flywheel for £600.
is the fly wheel standard or lightend :?
and what sort of power can the cluch take :D
Sirnixalot
Websnowbo said:
Is OS clutch heavy?
hellllls no its light.
martyn-300 said:
[color=blueso does that mean you get a cluch and flywheel for £600.
and what sort of power can the cluch take :D[/quote]
not standard...its an OS giken flywheel and yes its lighter than standard
