paulrandy
:lol: :lol: :lol:What is it with boyracers and dump valves......
Yeah, f o o k i n g CHAVS
yer tell me moreGartracS2 said:Anti lag is old school and wouldnt be on my shopping list. Your all twittering on about DV`s and chatter. Has anyone ever heard of a system whereby the excess air from off throttle between gear changes can be utilised by forcing into the exhaust turbine thereby keeping it spinning between gearchanges thus reducing lag? EGR system but inlet air is used as opposed to exhaust gas. You have no Dump Valve and no chatter and no lag. PERFECT.
Yeah montune do it, £2500 :roll:GartracS2 said:Anti lag is old school and wouldnt be on my shopping list. Your all twittering on about DV`s and chatter. Has anyone ever heard of a system whereby the excess air from off throttle between gear changes can be utilised by forcing into the exhaust turbine thereby keeping it spinning between gearchanges thus reducing lag? EGR system but inlet air is used as opposed to exhaust gas. You have no Dump Valve and no chatter and no lag. PERFECT.
So you mean like a recirculating dump valve.........AKA the stock systemGartracS2 said:Has anyone ever heard of a system whereby the excess air from off throttle between gear changes can be utilised by forcing into the exhaust turbine thereby keeping it spinning between gearchanges thus reducing lag? EGR system but inlet air is used as opposed to exhaust gas. You have no Dump Valve and no chatter and no lag. PERFECT.
:shock: Turbo opened, bits of compressor blade everywhere.MarkTurbo said:Can opened, worms everywhere :mrgreen:
Dont believe everthing thing you readAnonymous said::shock: Turbo opened, bits of compressor blade everywhere.MarkTurbo said:Can opened, worms everywhere :mrgreen:
Thought that was what happened with nowhere for boost to dump- plenty 'o backwash to ruin ur blades and slow as slow spool up :?:
That bit must be the biggest load of crap i've ever read :lol: :lol: :lol: :lol: :lol: :lol:5 - High pressure damage
If you use no DV or a high pressure DV spring then when the turbo is spinning at high speed and the throttle valve is snapped shut, there is a pressure pulse in the system
which can be high enough to damage the intercooler etc.
Best case - At boost below 1.5 bar you will probably be ok
Worst case - Bigger turbo's/ higher boost may pop hoses off or 'balloon' the intercooler core.
I think the guy was trying to give a conservative opinon covering all bases.... unlike yourself :lol: :roll: :lol:MarkTurbo said:That bit must be the biggest load of crap i've ever read :lol: :lol: :lol: :lol: :lol: :lol:5 - High pressure damage
Theres never going to be any more pressure going backwards than the turbo was producing in the first place :roll: You'd need a s**tload of pressure to "balloon the intercooler core" anyway :lol: :lol: :lol:
I hear what you're saying 8)MarkTurbo said:Just that bit about ballooning an intercooler :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
