Mine haven't turned up yet, although they left the US last Wednesday !!Cambridge_pulsar said:bump...
I'll stick up a review when they do and they're fitted !
If I'm honest, I can't feel any difference but, I guess you wouldn't and it's a good thing. The rear buffer large bush feels to be in the same condition (very un-rigid and loose in the bracket) as the front, pre-filling too though. So, I need to sort that ASAP.antgtir said:A friend of mine did the same thing to his engine mounts, he filled the voids within the bush with Sikoflex which has worked a treat, some people on the forums have said that this doesn't work but obviously they haven't seen or experienced this done8)
I don't have any pics mate but, the only difference you can see, is that the outer lips of the bush are shiny, instead of matte !antgtir said:Sounds great with the gear bush improvement, do you have any pics of this fitted now?
To be honest, I could modify the poly buffer bush I bought to fit, if I had a suitable tool to trim it with. I don't though so, I'll chalk it up to experience !campbellju said:Excellent post Paul.
Stumo made me a front engine mount from some dense rubber he had around and NVH got worse. The Silicon fill idea sounds like a good compromise.
I'll look into getting the gear box bush as well as gearbox movement is like a spoon in porridge.
Fancy a mini "group buy" Ant?
Jeddeh, it would seem that you can get a better deal than I would be able to, with your Air Canada contact.Jeddeh said:8 bucks shipped to my door for the shifter stabilizer from a local parts place. Do you want me to help organize anything? (I can also get a deal on Fedex shipping since a friend's mom is a flight attendant with Air Canada here. I think its 25% of retail for shipping anywhere in the world.![]()
Jesse,Jeddeh said:Please, call me Jesse. Jeddeh was a high school nickname that I use for online accounts.
Sounds good, and the store told me it would be $8 CDN. Now ordering a bulk shipment may give a bit better price as well.
And your plan sounds excellent. Remember, I only have a price on the shifter linkage bushing, not the engine mount ones. Once confirmed that some of them (or all) will fit, then I can also get these.
That's right mate, ARB does mean anti roll bar !Jeddeh said:whats an ARB? Anti Roll Bar? if so, I may get some buishings for my car since I think mine may be worn out. I will double check when I get some time to order and install them.
as for the engine mounts, I wonder if the b13 nx 2000 would take the bushings? the north american NX 2000 came with the sr20de, I could check here in NA to see if they fit with any of their many gtir motor swaps.
The Sentra ARB bushes should fit the GTiR, you just need to get the bushes for the correct size ARB. It looks like you need bushes for a 28mm bar at the front, and 15mm at the rear, according to Whiteline !Jeddeh said:I cant find ones for the GTiR on energy's site for the ARB's. maybe it's the fact that it is 4:30 am here and I'm still awake?:doh:
otherwise, does anybody know what the part # is?
and yes I have posted some threads on the sr20 forum asking the owners of GTiR motor swaps what bushings they are using if they've replaced any of them.
I also read on the modifiers club of a guy making his own urethane bushings that were alot stiffer than the OEM ones!![]()
