111mattin111
Yea I think that's where my oil is wheeping from does anyone have a pic of how it should be?
Also yep the two pipes are blocked off
Ditto.1) Never seen that used and my car has nothing connected there and is fine.
Additionally, if you've got the PCV deletion kit installed; those will also be blocked-off with nothing attached to them.2) Are those red tubes blocked off? Thats just a connection to balance the throttle bodies and if not blanked off will cause running problems.
Mine is just hooked over some hoses to hold it upright (spot it near the dump valve):3) Thats just a breather for the gearbox and should just have a pipe with a U shaped bend on the end attached, if you drive it hard enough you'll start chucking oil out without it.
Actually laughed out loud when I read that!Have you had driving lessons of Andy Chan :lol:
