RishiGTiR said:
There is no right or wrong cam for a particular turbo...
going to competely disagree there
and no i didn't copy this from a book
:lol:
an engine is a pump, all it does is pump air, which through the combustion process produces power, with a turbo you are forcing far more air into the engine.
The air can only get into and out of the engine through the valves, no other way. The valve is obviously controlled by the cam, How effectively the air flows that is generated by the turbo is all effected by pipe run, intercooler restriction, inlet manifold design, ports and the valves. On the exhaust side its obviously valves, ports, manifold, then the turbine, before it all f*cks off out the exhaust :lol:
A small turbo with a very long duration, high lift cam would be a complete waste of time as the turbo will not be able to flow enough air at the point the valves would be fully open for it to be beneficial, you'd never create enough air with a small turbo that the engine would be capable of using.
example for simplicity sake: tiny-nob turbos ltd weener turbo : power range 3000-7000rpm, why have a cam setup that would efficiently allow air flow to 10000rpm ?
A big turbo with too short a duration and low lift cam will be physically prevented by the cam set up from flowing the air that the turbo would be able to provide. All you'd end up with is a hideous, laggy, nasty to drive mobile waste of money
:lol:
example for simplicity sake : humdinger turbos inc : super todger turbo : power range 5000-9000rpm why have a cam set up that would only efficiently allow airflow to 7500rpm ?
On a small turbo you want it spooling at low revs, the small turbine wheel wont require loads of revs to get it going and if, for example, it was possible to rev the engine to say 9000rpm it would be miles out of its efficiency range
On a big turbo if you cant flow the air, you cant produce the exhaust gasses and you cant get the turbo spooling, so with the wrong cam set up you'd never be able to use anyhere near the airflow the turbo could provide, you'd would probably end up with a car slower than you had before
:lol: :lol: :lol:
for making the best power possible its all about getting the cam set up spot on to the turbo you are using 8) theres obviously more to it as other factors effect the power an engine will produce but this has been a far to sensible reply from me and my head hurts
:lol: ,
some of it might be worded badly
but thats about the jist of it
p.s the fact carl is interested in the gtrs puts him right inline for the tiny-nob turbos ltd : weener turbo :lol:
