As above,
This is what I found today.....really nice isn't it?
B13, B14, B15 Suspension Information...
Happy reading.
Happy reading.
I won the Welsh and the Midland Hill Climb Championships in my class using Teins, your springs and shocks are only a small part of making the car handle well..I had teins on mine and the car handling was superb, even on road use it was good.
This.So what you do with the car and how and where you drive it governs how you set it up.
I have BC coilovers on mine with camber adjustment things on the top. Anybody had any experience with them with handling and setup??
You need to be a bit more descriptive than this...it's like saying I won the marathon wearing Nike trainers .I had teins on mine and the car handling was superb, even on road use it was good.
That's great info for a set up start point. Thank you. Had no idea where to start as coilovers came on the car but just thrown on judging by caster angles they were at! Moved top mounts just to get the wheels to go in a straight direction!There ok if you take time to set it up properly and learn what suits the car best, I found taking 20mm from stock rear and 30mm from the front in ride height was about right and minimum damping on the front and two up on the back works for me on the road , but this is dependant on loads of other things.
