Sorry, I never said I wasn't going to be intercooled, I said I'd go back to the top mount again, maybe try and find one a bit more efficient if needed. I've already got WI which is a great help. The charger is quite small so will fit where the aircon pump used to be. Its a bit close to the exhaust, but nothing a small heat sheild can't fix. Good suggestion about mounting it above the alternator, never really considered that until now... ( just when I thought I had it all planned, lol
). I thought about mounting it dead on top of the block, inside the cheesgrater but I couldn't get a clear line to any of the pulleys without riggin up some elaborate slaves.
I never really considered an air/water intercooler but its definately a good idea 8) I won't be running anywhere near 2 bar to begin with, I was just pointing out that its possible to get the same boost from a charger as from a turbo. I know that bang for buck, a supercharger will always lose out to a reasonable turbo for all out power, but I'm just interested in the no lag/ power at idle throttle response. Most of my racing, sorry ahem, driving is in places where you can't spend ages screaming at 5000 rpm to keep the boost up
I can't see the point of having a car that makes peak torque at 5000rpm and peak bhp at 7000 rpm when I very rarely get to rev it that high in normal situations ( ie driving to work on my private airfield
I suppose there are arguments for and against dump valves, in any situation. Some people say they get better performance having positive pressure in the intake manifold before the throttle opens and the damage that is allegedly cause by stalling the turbine is not very common. Horses for courses I suppose, I've heard good arguments for both and wouldn't like to comment on which is better.
Thanks for the link btw, this is a bit of a prototype so any ideas I can glean from anywhere else is very welcome 8)
