Sunroof Problem
JohnnyGTiR
The sunroof in my R is leaking around the back L & R corners. Could this be blocked drain hoses or the seals?. The thing I noticed is when it is closed I can push the back of it up and down a small amount, is this normal?. And also could someone tell me where the drain hose outlets are.
Thanks in advance
D
daBOODA
If you look underneath the rear of the car, in the rear bar, you'll see two small metal tubes, coming out on either side. Both have a rubber boot that keeps them from rubbing against the metal plates in the rear bar.
If you take your boot lining out you'll be able to see the two drainage pipes going down to the rear bar.
I must say, though, that one of the metal tubes (that connect to the plastic tubes from the sunroof) in my car was totally rusted to hell. I thought this was the problem and replaced it with a rubber hose of roughly the same size. I still get leaks though, so I'm going to rip out the roof lining and try to see if there are any other blockages in the drainage tubes.
As promised months ago, I will take some photos of what I am talking about tonight as I've got a digital camera that someone lent me for my fibreglass adventures.
I can push the glass up on the back corners of mine :? It dosen't leak though. It does start flapping a bit at over 140 mph* though :shock:
*on the track of course :wink:
