Strut braces
jonesgti_r
Just fitted cusco front and rear braces and the whiteline front lower brace to the car.
Looks to be sitting higher than it did b4 is this right :?:
GTIR-LOZ
no, have you road tested it yet, the suspension might need to settle down a bit, or a spring might not be sitting in the cup properly
jonesgti_r
Finished it last night not been road tested yet and checked all the sprins they're fine.
Not stupidly on stilts high but def looks higher than before
SunnyGTIR
If u have had the car off the ground then it will sit higher when u put it back down on the floor until you move it and it settles back in. Have u moved it since doing the job?
