GTI-R Kid
Right lads, I've found myself in a bit of a pickle. The missus to be has told me tonight that as a wedding present I can get what I want up to a certain limit, and the 2 things that come to mind are a Power FC (fitted & set up) and a big-brake setup for the front of the car (4 pots with 310mm discs most likely).
Its one or the other, and I really don't know which way to go.:doh:
To assist your vote I can tell you that the car will be an everyday driver, running no more than 1.3bar boost on the standard turbo and more than likely left at 1.1bar for most journeys. The internals have been upgraded a bit, along with a higher capacity clutch. My driving has only ever once seen me expierence brake fade once (i must be light on the brakes and not trying hard enough?) and herself is a little more mechanically sympathetic. It will rarely ever see a track (due to the lack of facilities over here) so the only spirited driving it will see will be twisty B-roads.;-)
So which would you choose? Please give reasons too, and don't just vote?;-)
