turbodaily
adam im ganna go for a non screamer mate as ive had one before,not keen on the noise, makes the car sound like a vtec on throttle bodies (best way to describe it)
turbodaily said:strange, when i fitted one to my evo 3 it made no difference to noise on idle.
You need to read the rest of the thread !!nismo-400R said:if it does ill have one with screamer
Ive got an elbow which vents the wastegate side to atmosphere and i had to incorporate a divider into it which took a lot of p1ssing about with to get right. Even then it still leaked a small amount of exhaust gas from wastegate pipe when the car was idling and made it sound like i had a blowing exhaust :doh: Ive modified it now though ;-)youngsyp said:If you have a standard T28, a screamer pipe will not work as it's supposed to. The reason for this is that within the turbo's exhaust housing, there is no divider between the turbine wheel and wastegate
7,nismo-400r-Elbow & front pipe- screamer paidBraveheart said:You can put me down for one of these...
1,JPward- Elbow& front pipe - Screamer
2,Adam L - Elbow & Front pipe - Screamer
3,turbodaily - elbow @ front pipe - screamer
4,Adamski- Elbow & Front pipe- Screamer
5,rossdj- elbow and front pipe no screamer
6,Braveheart- Elbow & Front pipe- Screamer
jpward said:You dont have to get the screamer version you know its just a free option!!!!!
This debate has got even me thinking now? :?Adam L said:i know this, i still want the part but minus the screamer, my exhaust is loud enough without a screamer pipe and the wastegate gases venting off isn't going to give me any satisfaction through my ear drums nor performance, in my opinion (it's going to be so minimul it's not worth the agro i already have on the motorway)
i'll amend what i initially wanted
the best answer to that is, because Mitsubishi designed their turbo's far better than Garrett did;-)ashills said:it wont on an evo as it has a dividing wall built into the exhaust housing so u get a total seal with the gtir u have to have the sealing piece on the elbow flange and this can cause issues if u have a 3071 etc as the wheel in the exhaust housing is a lot bigger and could catch on divider
Hes got a bad attitude mate and he needs to sort it out.Adam L said:is that why we're privelaged with you're freshly shaved **** crack slightly to the left?
i'm not worried about attitude problems, infact, i'm not worried about anything, as i know exactly what a screamer pipe entails...marcymarc said:Hes got a bad attitude mate and he needs to sort it out.
