antopulsar
hi peps wonder if any one can help? wat plugs should i run when car is around the 400 mark. :x
They were NGK Racing plugs:roll:I have tried other spark plugs but I have been getting spark blow out on high boost so ideally I would like to have the same plugs that Ian had fitted previously, they were NGK's with tiny little tips if that helps
Were you just running the MSD Blaster Coil or were you using it with the MSD 6A Ignition Box..When the car was originally mapped by Ian @ Hi Teq it was running an MSD Blaster coil & Magnecore spark plug leads but the car was getting spark blow out at anything over 1.4bar
Interesting as i only run the msd blaster coil and get blow out at 1.7barWere you just running the MSD Blaster Coil or were you using it with the MSD 6A Ignition Box..
If you weren't using the 6A ignition box then you would end up with less of a spark than with the standard ignition..
Just the MSD Blaster Coil, did have the full MSD kit in a box in the boot but Ian @ hi teq said it was B0LL0X:lol: so he just fitted standard Nissan Parts with these NGK Racing plugs and its been fine since but I flooded the car trying to start it last week and have removed the plugs & want to replace them but unsure which ones they are???Were you just running the MSD Blaster Coil or were you using it with the MSD 6A Ignition Box..
it's pretty awesome 8)After fitting mine the garage called to say that the spark was bright enough to light up New York!
