ive checked the dizziy cap and its like new only replaced it a month ago same with the rotor arm,geetee said:Takes a very worn tensioner for a chain to jump a tooth.
Check the contacts inside the dizzy for pitting or charring (black)... any sign of change the cap and rotor arm. May be tracking or arcing.
If ur sure it is firing on 3 it could be an injector stuck shut. So pull the contact off each injector in turn and go for a spin........ one of them won't make a difference. Get it cleaned and flowed. Actually if this is the problem it is likely they are all gummed up, so get them all cleaned and flowed.
Graham
andygtir said:i had a rocker arm fall off and do the same thing. take the cover off and have a look.
Fast Guy said:It could be running very rich, that can make a car sound like a subaru sometimes. (ie like it's dropped a cylinder)
pulsarboby said:sounds to me like you've done a valve! is it popping out of exhaust on idle? listen for misfire on exhaust note
pulsarboby said:could be an injector but still sounds like a valve problem to me, especially if it does it under heavy load, maybe a sticking or leaky valve or valve spring bounce under load.
if it is popping from exhaust its definately got a misfire on a cylinder
pulsarboby said:no as it may be misfiring under load, especially if you have valve bounce.
and a compression check should be carried out on crank only with throttle wide open, so this alone will not show a problem if its a valve or spring.[/QUOTE
so how do i test to see if the valve is leaking? or not seating propery?
Fast Guy said:A Leak down test is the proper way to test if your valves are stuffed. It pressurises the cylinder, then checks the rate of leakage from the cylinder. If there's excessive leakage, you can tell what's leaking by where the leak is coming from.
Valves, head gasket, rings etc.
