skyline R33 calipers & discs??
Gaz gtiR
my freind has some aston martin calipers modified to fit his R33 so hes said i can have his standard front calipers & discs. :-D only thing is will they fit my R???
turugtir
You can fit any disc and caliper to your car if you make the adaptors for it. I believe the R33 calipers are almost the same as the S14/Z32, so you could put the N15 almera front hubs or make an adapter for them with your hub.
With the discs, you could redrill them if they are in good condition, and that's it
Gaz gtiR
sounds good then ill prob make adapters? sounds easyer than fitting hubs. as for redrilling the discs do u mean the wheel nut holes??
turugtir
Adapters is a good idea, as the N15 hub is 4x114.3 and you need to fit other wheels or redrill the hubs.
With redrilling the discs I mean handing them to somebody to drill 4 holes that fit your studs, as the skyline is 5x114.3. Although it could be worth it to go to a specialist supplier to see if they have any OE disk with similar characteristics, as that would save you having to redrill the discs every time you change them.
williams
its n16 hubs you need, not n15, they are the same as the pulsar. im going to see if my pulsar hubs will fit into the n16 hub assemblies, to save me redrilling the stud holes in the n16 hubs.
