Service needed
stomski
Guys,
What sparks du reckon i should purchase in prep for my R's service:
not sure what bar/boost its running, got forge d valve, full goose, kn induction, ap clutch, newish gearbox.
been quoted £65 for a set of plugs iridium, is that not a bit steep?
gona get mobil 1 15w 50 grade oil.
anything else i need to get for the guy to service? whats the part no for the oil filter?
thanks,
£65 is abit steep, I reckon they should be abit nearer £50.
If you doing the works on the service you'll need plugs, leads, rotor arm, dizzy cap, fuel filter, air filter, oil filter (15208 70J00 £5.20) , sump crushable washer, gearbox/transfer/rear diff oils. I think that's about it.
hmmm
i dont know much but from what i have seen 10w40 millers oil or 10w60 castrol rs has been recommended...
dont take my word fo it though get a pro to decide
Jamie_GTIR
10w 60 millers
though my tuner (JPS motorsport, supra specialists) used valvoline 5w 50 which worked a treat too
R
rsnissan
The standard plugs are platinum tipped so should need replacling las often as normal plugs.................they are good for about 60k. Just check the gaps and replace them if u are getting any probs like misfire or if u upped the boost to more than a bar
andygtir
also flush the rad, top up screen wash, and clean out the intercooler and oil seperator with petrol and dump some injector cleaner and 10k boost in to clear out the system. it makes a BIG difference. :D
