Self designed top mounts
Trip
you will need to enlarge the hole in the hub carrier so that you can use the original bolts. you won't get enough tension in a M10 bolt.
Will there be enough tension using original bolts to hold the hub carrier not moving ?
Do not remove the helper springs, if you do you will end up with a much higher ride height as it is dangerous to have a loose spring when the wheel is dropped.
You might want to get a different set of springs to suit what you want to do.
Jim mentioned a shorter spring. I will investigate :thumbsup:
