sard fuel regulator
Shaun
Yes mate it's fitted correctly,to adjust the pressure undo the nut and turn the vacum fitting,in to increase the pressure and out to decrease it,you need to set the pressure to 3bar(43psi) at idle with the vacum disconnected.When you reconnect the vacum it should read 36psi.Dont forget to block the vacum pipe when adjusting and the engine must be warmed up.
