I really didnt understand the logic in that statement mate. Its a piggyback also, so you can keep the std ECU. It makes no difference if you use it with or without the bigger turbo and injectors. It is the better option no matter how you look at it. Your choice (which i appreciate is yours) is like doing half a job. If you buy the Unichip in the first place it can be re-mapped in the future and will save you the cost of getting the JWT, then the Unichip. The JWT "chip" just has a general performance map on it anyway that they will have made on a slightly modded car and then burn onto anyones ECU that they send them. Its not anything special. The same as everyone else that has bought the chip off them. A Unichip or fully mappable ECU is tailored to your specific car and would not perform the same even on an identical spec GTi-R. If you were to choose the Unichip or other mappable ECU you would not require the S-AFC or any other form of engine control. The mappable ECU can take control over boost also so this saves you purchasing a boost controller.poetic said:i live in hampshire mate, the unichip may be worth concidering if i decide to put a bigger turbo on, and therefore have to uprate injectiors..etc.
save sending to jwt again..etc.
thanks
Not trying to sound cheeky but i cant understand why you are going down the route you are but its your car. Again not trying to sound like im on a high horse or anything.
