Rocker stoppers
LOU ROB
Anybody know who makes rocker stoppers and where I can get them :?:
Need them cause rev-limit is going up again :twisted:
Tomei and Hiteq for one :wink:
Norris do them , but not sure which ones.
I'd be very surprised if DP can't get them for you.
R
robinsongtir
Lou don't go revvving it as high as Marks if you fit rocker stoppers he is not on the same setup as yours and Jasons.
jiw
surely the cams will need changing too so that they allow more power higher up the rev range, also your valve springs will need uprating. What speed is your bottom end balanced to and to what balance grade, do you have a print out from when you had the bottom end balanced, it should be on their, jeff
LOU ROB
Its something iv'e been meaning to do for ages, just kept forgetting about them. It's more of peace of mind really :wink:
You won't find wilder cams than the ones I have fitted matey :wink:
