rev limiter
jjs
hi going to fit an aftermarket adjustable rev limiter, is says on fitting instructions that, if there is a ballast resistor fitted the wire going to the + side of the coil has to be fitted bettween the ignition and the ballast resistor, not between the ballast resistor and the coil, anybody have a wiring diagram, with wire colours, of the ignition system, or know where to tee into on the ignition system, cheers ( i think the silver box on the N/S strut top is a ballast resistor 6 wires going into the multiplug) ?
nismoboy
( i think the silver box on the N/S strut top is a ballast resistor 6 wires going into the multiplug) ?[/QUOTE]
nope thats the dropping resistor for the injectors, i think the ballast resisitor is the brown fuse like thing, its on the right hand side of the plenum attached to the injector wiring.
