Could you not weld the spacer plate to the manifold, then just use 1 manifold to head gasket ?Odin said:You'd need an of extra manifold gasket though.
I think that would be neater ?!
Manifold is Cast I think....youngsyp said:Could you not weld the spacer plate to the manifold, then just use 1 manifold to head gasket ?
Drill & thread 4 (or weld 4 studs into drilled holes) holes in the wedge then weld the wedge into position on the turbo flange of the manifold.pulsarboby said:just thought of another problem i will have, that someone may be able to answer:-D
when i fit a wedge in between turbo and manifold, how will i align studs so they go through the plate on the turbo! will i have to bend them, or what?
they will probably be 10 to 20 degree out of alignment.
:lol:stumo said:Just get a decent manifold:doh:
and, whats the problem with that................? you can weld pretty much anything to anything if your good enough ;-)Fazz said:Manifold is Cast I think....
pulsarboby said:how much of a spacer did you need Robbie?
Well if you look at any stainless manifold it has a full length flange, And you can buy these on their own if you know where to look, My idea was to just buy the flange and use it as a ready made spacer plate.pulsarboby said:so is it a complete plate that runs the length of the head, or 4 individual plates for each port?
not exactly sure what you mean, have you got a photo of it?
pulsarboby said:its all been dragging on toooo long for my liking.
