Rear wheel bearing...
C
charlie
How easy are these to do on the r? are they pressed in so i;m gonna have to take he hub off, or will i be able to do it on my driveway?
C
charlie
well i would edit my typos, but i can't edit my own posts :shock:
B
briitts
I have dont the fronts, and I needed to strip the entire front assembly. Got my local garage to press the bearings in for £10.
I think the rears are the same, but usually they are not pressed in like the fronts as they are not under as much pressure, with breaking and cornering etc.
Either way do it yourself and save a packet. :shock:
Tony
done fronts and backs, BIG hammer and punch to get the bearing out, then you just need to use a vice to press them back in, the bearings are available from your local bearing supplier for about £15-20, so you only need to buy the seals from nissan and get sum grease from sum where for free!!!!
Tony....
