K
kengtir
have to change the discs rear that is told that the wear rate has been reached so new disc replacement, need to now the size of the socket, to take the said nut off cheers all and thanks???
shaun you ife saver cheers mate ill have a go monday thanks again kenShaun said::-D Hi mate,what nut are you trying to remove?To remove your rear discs,jack up the car and support it with axle stands,remove the wheel and then release the hand brake,remove the caliper and then the caliper bracket,the disc should then just fall off,if its stuck,close to the centre of the disc are 2 threaded holes,put a spare bolt in either hole and tighten similtaniously unit it releases the disc.Fitting is reverse of removing.
What about all the ancills Rob what do you have to unplug/remove as minimum as i feel a new clutch on the horizon and 2 before were done "all out" jobs and costly tooThunder God said:Its only a couple of hours to drop the whole engine, I've done it both ways now and dropping the engine is by far the best way in my humble opinion.
