rear brake conversion
kirko
has anyone tried fitting the front discs and calipers to the rear :shock:
i know there is the hand brake etc. to deal with :shock:
or can you recommend a good conversion off the shelf :)
i cant get hold of a rear caliper to replace my broken one so am looking for other options :oops:
I think most use the std rear caliper, just spacing it out if a big brake conversion.
Other options will be ££££. Does the RC car have APs all round?
SunOnGTiR
I always thought about this.............can it be done?
kirko said:
not sure about the rc car
but i am struggling to find a rear caliper replacement
I think you maybe able to use the skyline rear caliper's with a bit of modding :wink: .
rob
boucherie
keeping on this theme, ive got the 2 disc 310mm willwoods upfront but as they are starting to wear down a bit could i split the disc and use just one of them on the rear making a 310mm rear conversion or if i was going to do that would i be better off putting the whole of the front end on the rear and then get some 324mm 4 pots for the front :?:
mad max
is their any point in uprated the rear discs to the standard size/groove and drilled would i feel the difference all ready got 4 pots on the front thanks
