Radiator question
Jedi-Gti-r
Cruising down the road the other day when some twat kicked his ball in the road,too late for me to avoid :evil:
Ever since i've been losing coolant.It's coming out from the nearside top area,not much but it needs sorting.
Do i need a new radiator or can i use radweld :oops: or any other cure.
Thanks in advance guys.
Paul
geetee
Chemical Metal if u can get to the hole.
I've always thought RadWeld and the like can't be a good idea, all that gunk whizzing around trying to block the water feed to your turbo :shock:
GeeTee 8)
Jedi-Gti-r
Good point mate.
Where can i get this Chemical metal from?
Thanks again.
T
Tart
..... or u can use "Sets Like Steel".... again only if u can see the hole! U can get this stuff from most car shops (possibly even Halfords, dare I say it). Excellent stuff....
Prob is the rad on the R is metal with the top guard being plastic. If the leak is coming from between the metal and plastic it is next to impossible to fix....... (unless u can get it apart!!!) If so id go for a new rad. There pricey new but sure u can pick up a second hand one. Nice Mr Ex-GTIR had one spare for £40 after I blew mine apart.... :oops:
..... and there easy to change......
Matt
geetee
Yep, Chemical Metal or Sets Like Steel - same stuff, different manufacturer.
Available from most motor spares places, Halfords and probably B&Q!
GeeTee
