Radiator Fans, ECU Fuse Blows
Sailor96
Problem for you gents,
Driving around running really well, not in a limp mode condition, but the fans weren't switching on and temps were rising dangerously above normal
I tried using nistune to diagnose the problem and couldn't connect through the consult cable initially. Found the 10A fuze was blown for the ECU (bottom right 4th up).
Managed to connect to the ECU with a higher amperage for only a moment, didn't see any temp sensor faults.
Disconnected the fans and put in another 10A fuse and it still blew.
New OEM Nissan fan relay I just installed last weekend and the fuse still popped.
Anyone had this issue before? TIA
