Time flies just as my money.. Pity i cannot say the same for the amount of upgrades I managed to squeeze since November.
Nothing confirmed but 2011 season should start around 2nd sunday of March. No date was announced but every year they start around this time.
I didn't do much as i was busy bulding my engine, after a fresh rebuild and one race, it was drinking coolant. I decided to give it a try myself (after my tuner's failure, i might as well do it myself) and opened it up and found the block needed some skimming. Put everything back in place, So far no coolant missing even after 30minutes of idling and giving her some gears with wheels off the ground.
New mods for this year:
Forged engine (build my me)
GT2860RS turbo with 1bar actuator
AVCR boost controller
Close ratio semi helical dog box (done by Drenth in Holland) with similar ratios of an RB
4 point lower strut brace
Longer wheel studs
New custom made shift light (still needs testing)
Item's i had on the agenda but had no time were :
20Ltr fuel surge tank
Full poly bushes at the rear
Bigger calipers at the rear together with new copper brake pipes and hydraulic hand brake
Z32Maf and 700cc injectors together with a mappable ecu.
Wide arches
New coilovers and custom made topmounts so i can play with camber, caster and track.
I am planning to run with 1bar of boost using a Field access ECU together with 100 Octane fuel. AVCR will be only used for better spool for now. I need to get used to the gearbox as it feels very different from what i am used to. I will be running some spacers front or rear depending how it goes in testing. Once i get new coilovers with different spring rates, and fit wider arches, i can play around 'trying' to get the car less understeer.
IF...IF (only if) i do not break it, the big jobs like brakes and fuel tank will be done in the summer break.
