Does the difference between 1.6 and 1.9 effect how soon your hitting full boost at all?
Bearing in mind that 1.9 bar is a higher full boost than 1.6 bar then it will always hit 1.6Bar faster ;-). If Ross were around he'd tell us to stop talking about boost level anyway and start talking about air flow.
If I put the engine under a high load in 5th then the rate of change is slower so the controller is less of an issue. The boost level becomes a function of the turbine speed and on my car 1.4 bar, 1.6 bar and 1.9bar ramp up at repeatable rpm and load points. This is just talking about boost though and as 1.9Bar generates more torque than 1.6bar its "faster"
If you are in 2nd gear holding 3.5Krpm in a typical 40mph overtake, you can pull out check its safe and when you accelerate it goes staright to 1.9Bar missing out everything in between. When you look at the logs of this you see the load cells going vertical. (It does ramp but again its mS)
So as well as the raod/engine conditions, there is also your setup which plays a huge part. I use a .64ar turbo with an appropraiately sized pace intercooler through a short pipe run. A smaller turbo with a larger ar using a bigger intercooler would probably be less responsive.
@bobby, it depends what you mean by faster. Most people with a 3071 can make 380hp around 1.4Bar without too much effort. A 2871 might potentially be more responsive but it would also be more strained when producing 380hp. A T28 isn't in the same league as a GT turbo, my 3071 starts generating 0.7Bar of boost from 2.5krpm then surges again at 3k.
@Chris, if you want drag racing and street then just get whatever maximum you can and use it for both. When on the street, use your right foot to modulate power.
