Alex
Can anyone give me a low down on Quaife gear boxes for the Pulsar? How much are they and what sort of a difference will they make? Any info would be appreciated.
Quaife ratios are slightly longer than standard for first 4 gears then same as standard in top.I want a box with some different ratios, slightly lower top speed but increased acceleration.
Boxes arent that bad, it depends how you treat them. Third to 4th selector is a week point. Theres some big power cars that still use standard boxes.sorry to butt in on this topic, but i've read and spoke to people about the gti-r's and know that the box's aren't that good when higher toque is being put through them and i know you can get Dog cut inners for 1-3rd gear.
question being are they alot harder to get on with conpaired to standard cut gears????
May i remind you that there has yet to be a GTiR Quaife failure!!... :?woodster said:sorry to butt in on this topic, but i've read and spoke to people about the gti-r's and know that the box's aren't that good when higher toque is being put through them and i know you can get Dog cut inners for 1-3rd gear.
thanks Woods![]()
ChrisS said:Quaife ratios are slightly longer than standard for first 4 gears then same as standard in top.I want a box with some different ratios, slightly lower top speed but increased acceleration.
woodster said:i'm bit of an animal with gear changes :roll:![]()
, i want to have a go at the RWYB and jap shows as a lot of my friends do it with there jap monsters
, i would probably be better with the quaife inners then?
What about that Dee1 (Darren) fella?? Didn't he wreck a Quaife box or two?? I could be wrong mind....RishiGTiR said:May i remind you that there has yet to be a GTiR Quaife failure!!... :?woodster said:sorry to butt in on this topic, but i've read and spoke to people about the gti-r's and know that the box's aren't that good when higher toque is being put through them and i know you can get Dog cut inners for 1-3rd gear.
thanks Woods![]()
Really no idea where you got the idea that it doesn't like high torque.... :? :roll:
Rishi
Mark_GTiR said:What about that Dee1 (Darren) fella?? Didn't he wreck a Quaife box or two?? I could be wrong mind....RishiGTiR said:May i remind you that there has yet to be a GTiR Quaife failure!!... :?woodster said:sorry to butt in on this topic, but i've read and spoke to people about the gti-r's and know that the box's aren't that good when higher toque is being put through them and i know you can get Dog cut inners for 1-3rd gear.
thanks Woods![]()
Rishi
You worried about the casing breaking rishi? You going to be using solid or standard mounts?I've launched mine 50+ times using a harsh 3 paddle HKS Ceramic Paddle Clutch with no mechanical sympathy and its all been fine...
I'll be running 700bhp through mine in week or so...
Was it the actual quaife gearset that failed though?What about that Dee1 (Darren) fella?? Didn't he wreck a Quaife box or two?? I could be wrong mind....
Be a bit kinder to it then then you wont need to fork out £3ki'm bit of an animal with gear changes
ChrisS said:You worried about the casing breaking rishi? You going to be using solid or standard mounts?I've launched mine 50+ times using a harsh 3 paddle HKS Ceramic Paddle Clutch with no mechanical sympathy and its all been fine...
Standard Engine Mounts.... Will have another case for some special treatment... Have also looked into getting a new casing made out of a much stronger material...
No the Quaife was fine... He blew the std casing...
Thats what you get for using solid mounts and solid disc clutch plates... A few days later he did it again...
Be a bit kinder to it then then you wont need to fork out £3ki'm bit of an animal with gear changes![]()
Would be interested to know how it goes.Will have another case for some special treatment... Have also looked into getting a new casing made out of a much stronger material
ChrisS said:Would be interested to know how it goes.Will have another case for some special treatment... Have also looked into getting a new casing made out of a much stronger material
Also running quaife, OS and standard mounts. Casing blowing gives me nightmares![]()
