Rising Sun Perfomance are pushing the AEM at the moment, they were trying to get me to use one but I already had the Power FC Pro ready to fit. Call them and see you might be suprised.
It won't work.If my MAF is maxed out at 1.6bar,it will keep telling the same voltage to the ECU for all higher boost figures.RishiGTiR said:All you do is rescale the MAF voltages so that it reads max voltage at a much higher airflow rate...
see above...It would be ok if my car was drag dedicated.But it will also be my track toy and I also use it for street racing (vs Porsches,sporty motorbikes,Supras,etc...)RishiGTiR said:Yes the Z32 will have its limits but its fine for the 500bhp that you want to run....
The Power FC is true good stuff when used with datalogit.And it has a 20x20 map which allow to do fine engine tuning. It only needs launch control to be one of the best MAF using ECU (oh, Power FC Pro!! lol ). I reckon I'd like Apexi to do the D Jetro version for GTIRs,but at the end of the day,as I said before,the only advantages of using a MAP sensor are:RishiGTiR said:You could always use the new AEM ECU... Its as flexible as the Motec but with the plug and play ease of the PowerFC... And it uses a MAP Senor..
Part number 30-1600.... I would recommend the AEM with UEGO part number 30-1600U...
Jobi Joba said:It won't work.If my MAF is maxed out at 1.6bar,it will keep telling the same voltage to the ECU for all higher boost figures.RishiGTiR said:All you do is rescale the MAF voltages so that it reads max voltage at a much higher airflow rate...
So nevermind all the rescale you want,you will still read the same load as soon as u go above 1.6bar. So you will inject the same amount of fuel and run the same ignition timing for 1.6bar or 2bar. It's just not proper tuning!!
I don't want to sacrifice mid boost points just to have a nice map when I run 2bar boost.
That's why I need a MAF which voltage is not maxed out at 450ish bhp.
So my question is:Is there someone here who is running a Q45 MAF?
I think the Z32 MAF is maxed out at about 4.8V...RishiGTiR said:It reads Air Flow vs Voltage... You can scale it to read max voltage 5.1v(i think) at for eg. 1350cfm...
I maxed my MAF using a GT2540R at 1.4 - 1.5bar... Yet a friend of mine manages 2.1bar on a much larger turbo...
All using the same method i stated.. Its all in the FC Software... It will get to the point where the MAF starts to lose acuracy but 550bhp is fine on the Z32...
Rishi
Me too....but i have no idea what you two were talking aboutRishiGTiR said:Will be using the Q45 myself...Rishi
yes, that works, you can also widen the MAF range by sticking a needle or something in front of the sensor so that more air flows around the sensor instead of through it...kieron said:if nissan mafs read 5volts max and the amount of airflow that will cause it to see 5volts is goverened by the internal bore size of the maf, could you not with abit of jiggery pokery take a standard maf, whip out the sensor part and make up your own huge housing for it to get far better air flow before it sees 5volts :?:
Im running a Q45 MAF and wiring diagram is on the OZ site and standard ecu with Safc II thou im running around 300 so i'll never max it out! :lol: :lol:Jobi Joba said:what about the Q45 MAF wiring?Can someone tell about that?
is the pro version the only version you can get for the gtir cos im having trouble trying to find any info on it for the gtir :roll:Don't tell me that i've just brought an FC pro
GTIR-LOZ said:is the pro version the only version you can get for the gtir cos im having trouble trying to find any info on it for the gtir :roll:Don't tell me that i've just brought an FC pro
