Putting things through the bulk head - like battery wire
dombat
I'm fitting a FMIC soon, so might relocated the battery and washer bottle if required.
I've had a look in the engine bay and cant seem to see any good places to get access so i can get a wire or pipe through the bulkhead into the cabin.
Where do you recommend?
I've removed the air condititioning, so if i remove the air con stuff inside the car as well the holes left will do, probably.
gtirx2
If you are looking at the engine, i used the large rubber gromet on the far right hand side of the bulk head,just along from where the a/c pipes come out to run my cables.
As for the washer bottle under the drivers side wing there is another gromet that i used that comes out down near the drivers feet.
