Some sunny days coming up ,so moving forward along the underside of the car .
not too bad underneath,mostly surface rust where it was stood and years of road crud old oil leaks , rubbers and bushes all look good .
Today fitted a solid gear shift mount (old one was perfect and little change to feel )and lower brace .
Question- has anybody used a laminova oil cooler?
I already have an normal oil cooler which sits on top of the engine , where the original intercooler was.
It works fine but looks cluttered in the bay .
I have a mocal laminova cooler which has the same oil fittings but is considerably smaller and easier to hide .
I also have a remote water stat (a billet housing with stock size stat in it) about 10cm long , so I can T in from the stock water line and supply the cooler with radiator water in a loop and choose a stat temp .
This would give good oil warm up and constant oil temps .
Or I could use the charge cooler water supply as the water lines are the same size and overcool the oil which would mean having it switched by solenoid only when oil temps rise too high then off again when they drop and need monitoring as you hoon around but have a fast warm up (the current cooler does add a Considerable time to oil warm up )
