madcabbie
Hey guys, I recently bought a second hand HKS EVC I.
I have just installed it, and I am getting maximum boost at all times when I floor it. Naturally I am stopping at about 14 psi so not to cause damage.
The instructions say that when the unit is off, it should switch back to standard boost . aka 10psi. But this isn't happening. The back controls for low and high boost are set at minimum as is the volume control.
BUT when I turn it on, all the boost light on the boost bar are lite up perminately.
I am running the power from the standard boost controller unit power wire. Think this could be part of the problem? Should I chenge it to the ignition coil. Not that I know what I am doing .
The vacuum hoses seem to be connected to the right spots as per there online instructions. http://www.hksusa.com/info/download.asp?id=1739#
It also says that the standard boost control unit should be disabled. Do they mean complete unplugged? Or just have the vacuum hoses off?
I was running a manual GFB boost controller with out a hitch.
Any suggestions? Advice on what to check?
Thanks
Thanks
