C
chris-b
right just fitted avc-r today. wired in all ok, but having problems with pressure sensor. i have tee-ed in to the orig sensor pipe (on o/s inner wing near batter) were also my defi boost gauge is. the boost reading on the avc-r is way off. its hardly goes into positive boost, mostly staying on a negative vacuum. the defi is showing boost accurately and normal. whats the deal here-- i have orig sensor, defi and avc-r sensor on this pipe.
secondly, i cant get the car to boost further than 0.9 ish bar. it was first set to about 40% duty then now 60% and still roughly the same--- is this becvause of above fault?
all the pipes are connected as per instructions.
any advise would be much appreciated- i wanna go over one bar!
thanks chris![Wink :wink: :wink:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
thanks chris
